Results 1 to 10 of 12
Thread: Passat rear brake help!!
    May 2013
    Mooroolbark, Melbourne
    Evening fellow Passat purchasers!
    Just wanted to get some background information.
    My mechanic has notified me my read brakes will need replacing soon, although I would normally do this myself he instructed me this was going to be a hard job. I feel out of my depth with the electronic rear brake. Noted I have not pulled the brakes apart I was wondering if anyone could shed some light on an estimation of cost and if I need a VW specialist to attend to the issue. Can anyone reccomend someone?
    Thanks guys,
    Mitch
    May 2013
    Sorry it's a 2008 tdi Passat wagon if that makes any difference!!
    Apr 2008
    I was read on another forum (I think VW PAssat Forum) that you need to plug VCDS and battery charger (to have constant 12V) and after that you can change rear brake pads if you have electronic handbrake.
    If I find complete DIY I will post here.
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Mar 2013
    Brisbane QLD
    its no harder than a normal rear brake set up.. 2 bolts to remove the caliper and 2 bolts to remove to pad holder. you just need VCDS to wind back and forward the pistons instead of manually and also carry out basic settings afterwards... VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2008
    Sydney/Canberra
    Correct. Due to the electronic parking brake, the motors on the calipers need to be retracted and reset with VCDS, or VagCom, or VAS-PC.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2013
    Thanks guys!!! that has helped a lot..
    Any rough estimations on price to get it done?? Thinking i might get the Park brake switch replaced as it faults sometimes... Is this common in the passat?
    Apr 2006
    VW Race HQ - Sydney
    VCDS winds the pistons back , but you still need to push them back manually .
    1 hour max labour !
    Bug_racer supports the rebellion of the euro revolution
    Mar 2008
    North Lake WA
    Re: Passat rear brake help!!
    I paid about $400 to get mine done at Pedders, but was not much cheaper than the dealer. Was on 2008 TDI wagon
    Sent from my Nexus 7 using Tapatalk 2
    WestOiler125
    MY13 Passat Alltrack
    125kW 2.0L TDi DSG
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by WestOiler125 View Post
    You paid $400 to get a set of rear pads replaced ?
    Pacific Paradise QLD
