yup old SE kit that one...
the guy i bought the car off said it was installed but he didnt know what phone it was im trying to figure out which phone so i can chuck it on talk handsfree
you will be hard pressed to find a working handset of the kit. I am assuming its a few years old? Depending on the type of kit you MAY be able to just change the cradle and then you are right to go. Not sure what sort of intergration it will give you though.
See if you can find the control box and get a model number so that you can see if they still make a handset that is compatible and or if it is the type that you can just change the cradle.
Contact a mobile installer if you need assistance.
Cheers and Good luck.
V6Passat
Here now!
