Results 1 to 7 of 7
Thread: Passat DSG
    Dec 2009
    Passat DSG
    Recently picked up a new (to me) Passat TDI and am a little concerned about how the gearbox reacts in reverse. when only light on the throttle it seems to feel like its going to stall. any ideas? or is this normal for the DSG. its a late 2006 model if that makes a difference.
    cheers
    Nov 2009
    SEQLD
    If its not stalling and not jerking in reverse, I wouldn't worry about. Drive it for a while and see what happens over time. The DSG takes some getting use to.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Sounds normal to me, will take you some getting used to.
    kogarah
    we have an uphill driveway and i have to give it a bootfull in reverse to get to go anywhere
    Feb 2009
    Quote Originally Posted by dammfool View Post
    Same here,it takes some time to get used to it.Mine also had faulty mechatronic module reversing it then was very difficult task,all good now.
    Mar 2008
    North Lake WA
    Unhappy
    Reversing up any slope is a handful, but with "autohold" ON it is much easier. The car likes to roll with gravity otherwise, which can be quite disconcerting.
    WestOiler125
    MY13 Passat Alltrack
    125kW 2.0L TDi DSG
    Dec 2007
    ivanhoe vic
    strange mine is starting to stall occasionally when changing from reverse to 1st and vice versa both when cold and after being warmed up during slow speed manouvres.
    B6 Passat Wagon No KESSY
