Results 1 to 10 of 47
Thread: Tyre Pressure Indicator didn't go off and tyre damaged
    One of the front tyres of my 9 month old 125TDI hit a nail the other day (I have done only 5200km). It went completely flat when I noticed the wobbling. The tyre pressure indicator has never gone off. I read from the forum that the indcator needs to be set. I would expect the dealer has set that up when I collect the car! Not happy...
    Kmart told me the tyre has too much damage and needs to be replaced and the Continental tyre will cost $488 fitted. Is this a fair price? Any recomendationson tyre dealers?
    Jan 2008
    Melbun
    Quote Originally Posted by sylvester View Post
    i'm guessing its a 235/45/17 conti csc2? should be able to get a bit cheaper than that. ring around. bummer about the tyre.
    2x Caddy, 1x Ducato
    Melbourne, Inner East.
    I had a similar problem with a builder's nail in the sidewall of my front left tyre. Beaurepairs said it was unrepairable and a new Conty was going to set me back $400+. The guy there suggested I go for a similar Dunlop which I use as the spare. This cost half as much. The low pressure gauge worked as it should alerting me to the slow leak in the first instance.
    Point Cook, Vic
    the tyre pressure monitor only works for slow leaks as you have to drive for a while at the reduced pressure from memory.
    I think its assumed that if your tyre deflates dramatically then you should be able to notice it anyways.
    FOLLOW US ON FACEBOOK
    Jan 2009
    Pakenham
    Sorry if this sounds harsh but I don't really think it's fair to blame the dealer. You should NEVER take it for granted that the dealer has done anything.
    ALWAYS check things for yourself. After all, it's your car.
    Quote Originally Posted by Autopia View Post
    We are not talking about a $3000 Tata here so there is a level of expectation of service. Besides, there are easy things to check but some are much harder and you do rely on the 'expert'. To the extreme: Have you check your airbag? If it doesn't work when it needs to, I wonder if you will still say the same...
