Passat Brake issue - Help
Hi Guys, I have a brake problem with my 07 V6 Passat that the forum may be able to solve. So far my local dealer and VW Aust are at a loss to explain what has happened.
I recently had the rear brakes inspected as there was scraping noise coming from the left rear during braking.
On inspection it was revealed that the inside brake pad of the rear left had worn down to nothing, the scraping noise was metal on metal as the brake was applied. An inspection of the other rear inside pad revealed the same thing.
The car had only recently had its 60,000km service with the brake pads then showing 7mm on the front and 5mm on the rear at that service. However, it transpired those figures were for the outside pad. It appears inside pads are not (or weren't) inspected. $600 later through new rear disks and pads no one has an answer as to why the inside pads wore away to nothing. As there is currently no answer there is no fix, meaning this will probably happen again.
Has anyone heard of this or have an idea what the dealership should be looking at or doing?? Happy to answer any questions you have.
Thanks in advance.
Man In Black (MIB)
2007 V6 4Motion Passat, Black, Leather, DSG, 18" Wheels, Bi-xenons
2010 Mk 6 Golf R, 5-dr, Rising Blue, DSG, leather, ACC, RVC
