Highlander, the brake pads were checked at the 60K service. They said I had 5 mm, but it has since transpired they only check the outside pad. I guess it's too much work to remove the guard and look at the inside pad.
Some of the comments on this thread have been enlightening however, I was asked at the dealership if the brake warning light came on. It didn't. We're not sure why it didn't (as that's its job) but it has been suggested that the pad sensor is located on the outside pad. Which is counter to the practice of the insides wearing first due to the position of the piston.
I paid for new pads and disks as euro ventilated disks cannot be machined. Also, 60k isn't bad for euro brakes, so I'm told. I guess the issue is the sloppy job they did checking them. As I've said before, I'll be asking for 8 numbers next time any of my cars are in for a service; inside outside front left right and inside outside rear left right.
