easy fix - forget roll bars (do them last if you have to, but be careful with them), just drop in a set of H&R springs or similar that will drop it about 30mm, and a set of 19" wheels if you're running the 17" OEM's. If you're running the 18", personally I wouldn't bother with the 19" - but they will give you a bit more, but big cost. The springs will stiffen it all up for you and flatten out that cornering nicely. AND, it's a cheap, easy mod too!
