Results 1 to 10 of 10
Thread: Passat B7 dash rattle/squeak fix
    Oct 2013
    Adelaide, Southside
    Post Passat B7 dash rattle/squeak fix
    Prior to buying a Passat I read reviews where author(s) complained of dash rattles or squeaking & when I drove for the first time I too noticed this annoying sound emanating from the dash when I ran over a bump. I figured it was an easy fix after noticing it was the faux brushed aluminium insert.
    After 4 months of ownership I got tired of this annoying sound & it finally got the better of me so a couple of days ago I fixed it.
    As I have owned several 4wd's & actually used them for their intended purpose I became good at resolving annoying rattles & squeaks from interior trims. I have pulled many car interiors apart to resolve unwanted sounds & also to quieten/reduce road & engine noise.
    Let's face it plastic against plastic or plastic against metal will rub unless something is placed to separate as well provide absorption of vibration. Outback coarse bitumen or dirt roads will test any car or simply a drive to the local shops on our crappy roads – especially NSW. My tried & well tested favourite is felt. Years ago I bought a 1mtr piece of black felt from Spotlight which provided several cars with rattle & squeak free motoring that should have been resolved in development & production prior to being unloaded onto the public.
    I did notice some screws missing from the binnacle housing as they were not fixed in production. Hhhmmm......not happy Mr VW I have no doubt this would have contributed to the rattle/squeak.
    Firstly the fascia needs to be removed. I found this great video which guided me, although from a CC it's the same. I have added a little bit on the 2nd link showing how to remove the surround from the binnacle where Matt removed with his fingers I used the tool.
    www.youtube.com/watch?v=EOCdHQ8K-wk
    www.youtube.com/watch?v=nRo8YOK79Bk&feature=youtu.be
    watch here for the rattle fix:
    www.youtube.com/watch?v=yZL_ZtdEl9E
    Thanks mate I gotta fix my car too!
    Oct 2013
    Adelaide, Southside
    Quote Originally Posted by enixsr View Post
    Glad to help, post here to let us all know if it worked for you.
    Dec 2007
    ivanhoe vic
    That's weird never had a rattle or squeak with my b6
    B6 Passat Wagon No KESSY
    Pacific Paradise QLD
    I fixed mine by putting a piece of foam down the bottom of the drivers side glovebox between the two hinges.
    It rattled away on rough seal and I spent hours trying all sorts of remedies.
    Finally tried this and it has worked so far.
    Oct 2013
    Adelaide, Southside
    Excellent Some of the roads around where I am are really chopped up due to roadworks & not a bit of noise has occurred, it works a treat.
    Mar 2013
    Thanks Passcruiser. Great tutorial.
    How would one get his hands on the removal tool?
    2013 Passat Alltrack, Black, Pano Roof
    Quote Originally Posted by AllBlack View Post
    ebay: search "automotive panel prying tool"
    Jaycar also sell a trim removal kit. I got one from there about 6 months ago. Good quality and they work well. $25 if i remember correctly and comes with 3 or 4 different tools.
    Oct 2013
    Adelaide, Southside
    Thanks. Tools are available as mentioned by Sylvester & Lucas_R & will save any possible damage to trim. Post to let us know if works.
