Hi There, anyone know where the can bus gateway is located on a B6 Passat.Also what model do I need for upgrade to stop battery drain after fitting RCD 510.
I didn't need to change the gateway on my B6 passat (2006) when I installed on RNS-510. They use a different gateway to golfs and it seems battery drain is not an issue.
my '06 had it behind the climate control head from memory.
I am not sure which revision you need, but I went with a 2008 one from a wrecked CC and it solved my battery drain problem
I don't know if a Golf one would work but I didn't want to muck around with it
not all RNS510s drain batterys - those before firmware 1100 would not drain the earlier cars.
Thanks for your help. I fitted a later RCD510 with the RV camera port Version 2 I think.So the earlier model may not have the battery drain problem
we put a Golf Gateway in mine for installing the 310...
no problems here. apart from the Car not being coded correclty for steering lock...
Scratch my Earlier Comment..
Yes the Golf Can Gateways work
HOWEVER there are problems where it doesnt know how to interface correctly with the Steering Wheel lock on the Passat etc and several other computers in the system!
The Correct Gateway to get hold of in order to Solve Battery Drain issues is the following part number for the 3C Passat
3C0 907 530 Q
H/W: 3C0 907 530
You will need access to VCDS to re establish all the correct codings..
My 3C0 907 530 Q CAN Gateway is on its way to me now
other wise We got a quote today from the Dealership for about NZD450 ex singapore
Oh and the Can Gateway is heaps easier to get to on the Passat than the Golf
The Can Gateway is sitting in a small bracket behind the HVAC (Aircon Controls) Unit pop the trim off and the four Torx Screws and you can reach in and unclip it and then remove the plug.
Sounds like the q version u bought is not a 3C0 one or it is buggerd
It sounds like its stuffed what vag com are u using did u initialize the unit
Hey ranton, sorry for bringing up an old thread but did you ever figure out how to resolve the steering lock issues?
