Results 1 to 2 of 2
Thread: Spark plugs.
    Mar 2016
    Perth WA
    Spark plugs.
    G’dayguys – my 2011 Passat 118 TSI has hit the magical 60000k’s and it is time tochange the spark plugs.
    I amhaving a bit of a hard time trying to find what plugs to put in it.
    NGK listsa platinum part number for it [PFR7S8EG] but do not show an iridium equivalent.I would prefer to use iridium if possible but not absolutely.
    There isan NGK iridium plug [BKR7EIX] which looks like it will do the job but it showsup as a slightly colder plug than stock which may not be the best choice in astock engine.
    Failingall that, I’ll probably just end up using the Bosch platinum plug [FR5KPP332S].
    Anyonehad any experience with plugs for these engines?
    Cheers.
    Erskineville, NSW
    Have a look at the Denso range. That's what I use and they are cheaper than NGK.
