Results 1 to 4 of 4
Thread: Passat B5.5 1.9TDI Europe 2004 AC Compressor Squeel Noise.
    Mar 2008
    Central Coast but currently living Bosnia
    Hey guys
    Currently in europe and bought my self a passat.
    Everything seems ok mechanicaly except when i start my engine with ac on, the compressor makes a very very loud sqweel of a noise but if i put up the revs it goes away and ac working normal, so i was wondering is this a bearing issue or a compressor issue, as one is cheap and the other is not, once revs are up all is well but if i start the car with AC on the noise unbearable.
    Any help much appreciated.
    2010 Jetta 2.0l TDI 103
    2010 Passat CC 2.0l TDI 125
    2011 Passat 2.0l TDI 125
    Nov 2010
    I'm not mechanically minded at all but it sounds like a belt issue. It could be slipping.
    Mar 2008
    it most likely is slipping, when the compressor is not on its not slipping but the pulley spins still (bels still spinning), but when the clutch of the ac compressor is engaged it then makes a squelching noise, so i am trying to work out if its the compressor or a bearing in the clutch assembly.
    Nov 2010
    It could be the extra strain due to the compressor engaging that is causing the slip. Get it checked out mate. Probably isn't a big issue.
