Results 11 to 20 of 24
Thread: Passat 2009 tdi tyre recommendations
    Jan 2013
    When first fitted they were significantly quieter than the ContiSportContact2 or the KU31 Kumho that I had previously. Now that they are under 50% they can be noisy on certain road surfaces. The smoother, newer the road the worse they are. It also depends on the wheel alignment - very quiet last year after i had an alignment done, then I pulled the front suspension apart in March & they got a bit noisy again and I doubt that the setting changed more than a mm or 2.
    If you are really concerned about noise then the Toyo Teo+ & Yokohama DB are very quiet.
    Michelin PS3 are a great all-rounder too but you won't quite get the mileage of the Primacy HP.
    I believe theres a new Primacy out now as well Primacy3?
    I will probably go for nokian tyres...
    here is link:
    Nokian Passenger Car Tyres
    Erskineville, NSW
    Good luck with that. They would be a step or 2 below what I was recomending but if the price is right...
    Keep in mind that Nokian are a Northern European brand that promote their abilityy in cold climates / snow. Maybe they won't fair so well in Australian heat.
    For the sake of $40(??) a tyre I wouldn't bother. I've had dissapointing tyres before & having to live with them for 2 or 3 years gets annoying. Every drive is like having your missus say "I told you so"
    Jan 2013
    that is right...I think, i need time to decide which one will go on my car...anyway, thank you for suggestions ;D I will consider all options..
    Jan 2013
    Michelin Primacy (I've got 65,000km out of my Primacy HP & still have 2.5mm before they hit the wear bars).
    Toyo Teo
    yokohama DB
    Continental Premium Contact
    You're probably looking around the $150-$180 mark for those. There are cheaper tyres but you'll soon forget the price.
    Ok...after research i got two solution:
    - toyo teo
    - bridgstone potenza adrenallin r002
    What do you think?
    Regards
    Aug 2012
    Perth WA
    Quote Originally Posted by saint70 View Post
    - toyo teo
    What do you think?
    Regards
    Bridgestone RE002. It is a performance oriented tyre with excellent wet and dry grip and handling. Excellent performance for the dollar. Maybe a tiny bit noisy if you are looking for a super quiet tyre. Loved them on my previous Liberty GT turbo.
    I can't comment on the Toyo.
    Jan 2013
    Thank you for answer
    Jan 2009
    You should give the newly released Michelin Primacy 3 ST a try, which appears to be specifically designed to give a quiet ride.
    Being a Michelin, it's also likely to give a decent tread life.
    Erskineville, NSW
    - toyo teo
    What do you think?
    Regards
    Adreniline is a good tyre & Amalgam describes it very accurately.
    Toyo Teo would better suit what appears to be your driving style but you wouldn't be dissapointed in the Bridgestone. (or the new Primacy)
    Jan 2013
    I am currently running bridgestone potenza and i am happy with it...Just looking for few opinions regarding new tyres.
    I checked new Primacy and apparently thet wearing fast...I stick with bridgestone
    Aug 2012
    Perth WA
    If you are a Bridgestone user you won't be disappointed.
