I am looking for 4 x 17'' new tyres...Any recommendation?
Are you a plodder or a "racer"?
Budget?
+1 OEM on my MY12.5 125TDI and they provide excellent wet and dry properties.
If the budget is a little tighter, I would look at the Bridgestone RE002 Adrenalin. Great tyre but slightly noisier that the SportContact5. Both are performance oriented tyres.
For a touring tyre, look at Michelin Primacy. It is a very quite and comfortable tyre.
I have driven on all the above tyres on various cars that I have or current own.
I am driving like old fart...no, i am not racer
What about toyo+?
Michelin Primacy (I've got 65,000km out of my Primacy HP & still have 2.5mm before they hit the wear bars).
Toyo Teo
yokohama DB
Continental Premium Contact
You're probably looking around the $150-$180 mark for those. There are cheaper tyres but you'll soon forget the price.
I will be sticking to the conti's as I have almost 90000'ks so far and hoping for over 100,000, still
seems heaps left yet.
I read about Michelin primacy..many people complain about noise...is that true?
When first fitted they were significantly quieter than the ContiSportContact2 or the KU31 Kumho that I had previously. Now that they are under 50% they can be noisy on certain road surfaces. The smoother, newer the road the worse they are. It also depends on the wheel alignment - very quiet last year after i had an alignment done, then I pulled the front suspension apart in March & they got a bit noisy again and I doubt that the setting changed more than a mm or 2.
If you are really concerned about noise then the Toyo Teo+ & Yokohama DB are very quiet.
Michelin PS3 are a great all-rounder too but you won't quite get the mileage of the Primacy HP.
I believe theres a new Primacy out now as well Primacy3?
