Results 1 to 9 of 9
Thread: Passat 130 TDI transmission 'sliping'
    Mar 2014
    melbourne VIC
    Hello All,
    I had a disconcerting experience with my 2014 Passat 130 TDI yesterday. The car has 35,000km on the clock.
    I was parked on an incline and a friend had parked close behind me. I put the car in D and took my foot off the brake to drive away. The car immediately starting rolling backwards. It hit the brake, checked I was actually in D and tried again. Same thing. By then I was uncomfortable close to my friend's bull-bar, so I used my left foot on the brake to hold the car while accelerating with my right foot until the transmission engaged and I was able to drive away.
    Later that day I had exactly the same problem reversing out of a sloping driveway with a car in front of me.
    Auto Hold was switched off, but I didn't think the transmission NEEDED the Auto Hold to function properly on a hill start. Have I got that wrong?
    Penguin, TAS
    This is normal for a DSG gearbox. I always try to remember that it is technically a manual gearbox and just like a manual if you aren't quick enough from the brake to the accelerator/clutch you can roll back or forth on an incline. I presume this is why VW includes the Auto-hold function.
    2017 VW Tiguan 140TDI Highline
    2012 VW Touareg V6 TDI
    1985 Mercedes-Benz 380SE
    Mar 2014
    melbourne VIC
    OK, thanks for the reply. I'm surprised I haven't experienced this before now.
    Nov 2009
    North Shore, Sydney, NSW
    Spot on...!
    Quote Originally Posted by Lindsay View Post
    * MY12 B7 Passat V6 4-motion Highline wagon....
    * Sport pack (Kansas wheels) - Active cruise City EB - Driver Assist Vis pack - Auto tailgate - Candy White with dark tint.
    May 2010
    Melbourne, VIC
    You can also use the parking brake - engage it, and then when you apply enough throttle to overcome the incline, the park brake will automatically release.
    Mar 2015
    NSW
    Auto hold is best kept on if you want to let the car sort itself out rather than the driver having to figure out such manoeuvres
    Sent from my LG-D802 using Tapatalk
    Mar 2014
    melbourne VIC
    Thanks again. I'm not sure why the Auto Hold was off. It's usually on. Maybe my L Plater son was fiddling with buttons.
    Apr 2015
    Brsbane QLD Australia
    If your drivers door is open or your seat belt is not on then autohold does not function. Put autohold on with the button lit and remove your seatbelt. Autohold will turn off. A lot of people dont have there seatbelts on when moving out of a tight spot...so think autohold doesnt work.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
    Mar 2014
    melbourne VIC
    Thanks Darkhorse. You're right. I think that might have been what happened.
