Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Parking Brake Fault?
    Feb 2008
    Perth WA
    I have had two parking brake buttons fail... both replaced under warranty.
    First time it happened, the brake refused to release (couldn't go anywhere). Roadside assist disconnected the battery for 5 mins ... then restarted the car to get me going again.
    Mk 7.5 Golf R
    Aug 2007
    Ok there is a known fault with these. Even if you fit a new one it thats not enough. there is a superseded part number for the switch but if you fit it and try and clear the fault it will remain. You must do a terminal 30 reset to clear the fault. All good and not too much to worry about.
    Done plenty
    Jmac
    Alba European
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Jayse View Post
    I just had my 31,000km/2 yr service 2 weeks ago and the fault has only started this week...bugger.
    Umai Naa, does it take them long to change over the faulty button?
    Cheers,
    Jayse.
    No, mate. Not at all. Probably a 30 minute turn-around.
    Quote Originally Posted by Jmac View Post
    Done plenty
    Jmac
    Spot-on, Jmac. The part number went from a B to a C.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Queensland, Australia
    I had a similar problem to this, they R&R'd the switch under warranty in about half an hour.
    I can confirm the change in part number discussed above.
    Tony.
    2008 Passat 125TDI DSG, Leather.
    2007 MkV Golf GTI - APR, 188kW, Leather, Manual.
