Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: P0101 error @ 3 months old ?
    Nov 2009
    North Shore, Sydney, NSW
    Mate, I reckon as VW has advised there was an air flow issue & done work to remedy that & then subsequently told you there is no further problem with the warning light being on they have acknowledged that their own diagnostics cannot find an issue therfore suggesting there is actually nothing wrong. This being the case it is reasonable to assume on your part that if the light comes back on it means there is no problem needing attention. Unless VW tells you 'yes come back if the light appears again' then they are basically inferring there is now no issue. Now don't take this as gospel just a point of discussion of which I have a few on this.....
    Another point, short of this constantly doing your head in just take it back whenever the light appears, cover your bases mate. Have they ever mentioned over sensative sensors (if that is possible) or replacing any sensors..?
    Quote Originally Posted by sa-r32 View Post
    Over the weekend the engine light decided to just go away, but as I was already booked in to the dealer for Monday I still left it with them to see if they could fix it.
    So it was in with the dealer all day Monday, they couldn't find any issues, updated some software, cleared the code.
    To my surprise (NOT) the engine light has appeared again this morning. This is getting very frustrating, this shouldn't be happening in a vehicle this new and expensive.
    I'm tempted to just ignore the light and see if it goes away, the risk is what if I damage the engine, because I'm assuming it's the same issue.
    Anyone got any ideas on what I could do ?
    Thanks
    Paul
    * MY12 B7 Passat V6 4-motion Highline wagon....
    * Sport pack (Kansas wheels) - Active cruise City EB - Driver Assist Vis pack - Auto tailgate - Candy White with dark tint.
    Dec 2008
    Goods news, I hope.
    I'm not entirely sure of the terminology or if I'm describing it properly, so be nice guys.
    The dealer had the car for 3.5 days this week and appear to have found and fixed the problem. They showed me a photo of an o-ring that had been crimped/creased when being installed in the factory. This o-ring is used in a join somewhere in the air intake plumbing, the crimp/damage meant that a tiny amount of unfiltered air was entering the system and affecting the pressure. It wasn't until they lifted the o-ring out that the damage could be seen, as it was on the underside.
    Fingers crossed this long running saga is now over.
    Paul
    Took delivery 17 June 2011- Passat CC V6 FSI Candy White
    Sat Nav, Reversing Camera, Adaptive Cruise, Walnut & Lighting Pack
