Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: our Passat
    Volksfolks Guest
    Quote Originally Posted by Rednut
    i'd be replacing those rims with the old ones.. each to their own i guess tho
    was thinks on simlar lines, a little dark ay, i have a set of alloy silver, might change them soon..
    brackie, sorry fella was out most of the day anyhow, will PM you address for future, k
    Andy
    ming Guest
    Wink Help !!! about Passat I would like to buy
    Hi Guys,
    I would like to purchase a 1998 passat, however, I'm not sure normally how much it will cost to service as well as the price of the some parts..Eg, timing belt, brake pads...etc.. If any passat folks has some ideas or experiences to change parts, could you please......provide the price of it?....
    thanks very much in advance.....
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by aprr32
    W8 cluster(instruments I assume), does the 8 cylinder tach work with the 4 or 6 cylinder engine or is it a VW option that is in appearance only?
    I think he means the interior light cluster , its a common mod in the US .
    There is no way an instrument cluster could be swapped since the clusters are now coded with Vin numbers
    Hi ming,
    The passat costs no more to service that any other VW/Audi, most of the parts are the same. If you are looking at cars for sale, the most common problems to look for are:
    1. Water leaks from the windscreen: check that the front carpets are not damp
    2. Front ball joints: the passat has the same multi-link setup as the audi A4. Try shaking the front wheels and driving over some speed humps at different angles to see if there are any clonking noises. The joins are easy to replace.
    The passat is a good solid car - I have a 99 wagon and am very happy with it!
    There is also a huge amount of passat specific information at http://www.passatworld.com It's mostly american and european, but useful anyhow.
    Cheers, Peter
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by peter_j_g
    Hi ming,
    Cheers, Peter
    There is nothing wrong with lower ball joints ???
    There is a re-call on these lower ball joints , dont know why never seen any fail .
    bigger issues with tie rod ends (recall on these only early Passats)
    control arms wear out and start knocking
    Water leaks ? Ive only seen a few VW's leak water , generally its from the plug connection point where the engine ecu is and also near the pollen filter on the other side .
    Recalls on these include tie rod ends , immobilizer activating when interior of temperature of vehicle exceeds 45 degrees c and lately the lower control arm
    Another service campaign includes the turbo oil feed pipe heatshield . The early Passats use to blow turbos constantly due to the pipe running so close to the catalytic converter .
    There are heaps more things to look out for .PM me if you want individual details
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Passat 2.0TDI Wagon ::Review by The Age::
    Last Post: 01-03-2007, 09:57 PM
  3. Replies: 9
    Last Post: 18-02-2007, 09:56 AM
  4. Replies: 0
    Last Post: 07-02-2007, 12:12 PM
  5. $400 long haul passat
    By 20v kit car in forum Passat (B4 & B5)
    Last Post: 09-08-2005, 10:16 PM
