the options for travel are on & off & the alt speed distance is just a tick to select it. Any idea what these options are exactly? thanks in advance.
Hi guys,
I have 2 options not explained in my manual for the multifunction display plus, wondering if anyone has any info on it. they are both on the first menu of the mfd setup.
1 is travel & 2 is alt speed distance
Do you mean "Alt Speed DISPLAY"? Mine has that, and it adds a permanent digital readout to the MFD somewhere I think from memory...
oh yeah alt speed display came down with a virus today & my head is feeling all fuddy what about travel? what does that do? thanks ian
NFI.....
Which menu is it in, and what is the sequence, i.e. where is it?
if you tick the alt speed display it shows up mph where the temperature display normally is, temp moves up
When I got the car I asked whether you could make the alt speed display read in km/h but according to the manual and other members you cannot.
dunno what travel is - what MY is your car?
Pete
MY13 Octavia vRS TDI DSG
My alt speed is in kph. Pretty sure that's changable. Rode the motorbike to work today so don't have the manual handy but will double check the MFD settings when I get home.
MY09. It appears in the mfd settings menu where there is
mfd data
convenience
lights & vision
Language
Units
Auto Hold & then
travel
then
service
factory reset
rocket, am keen to know how you changed the alt speed display to kph as well. Same as pana's mine is also mph.
It's called the "Alternate" display because it shows the opposite to what is on the speedo - it's for when in Europe (kmh) for example you travel to the UK (that uses mph), so you can still have a speedo that works...
I believe that enabling the "Alt Speed Display" on Aus spec cars with speedos in KMH will only display in MPH. Unless Rocket36's car is special...
