Results 1 to 10 of 18
Thread: ? options in multi function display plus
    Oct 2009
    kensington, nsw
    Hi guys,
    I have 2 options not explained in my manual for the multifunction display plus, wondering if anyone has any info on it. they are both on the first menu of the mfd setup.
    1 is travel & 2 is alt speed distance
    Oct 2009
    kensington, nsw
    the options for travel are on & off & the alt speed distance is just a tick to select it. Any idea what these options are exactly? thanks in advance.
    Feb 2009
    Do you mean "Alt Speed DISPLAY"? Mine has that, and it adds a permanent digital readout to the MFD somewhere I think from memory...
    Oct 2009
    kensington, nsw
    oh yeah alt speed display came down with a virus today & my head is feeling all fuddy what about travel? what does that do? thanks ian
    Feb 2009
    NFI.....
    Which menu is it in, and what is the sequence, i.e. where is it?
    May 2009
    if you tick the alt speed display it shows up mph where the temperature display normally is, temp moves up
    When I got the car I asked whether you could make the alt speed display read in km/h but according to the manual and other members you cannot.
    dunno what travel is - what MY is your car?
    Pete
    MY13 Octavia vRS TDI DSG
    Apr 2009
    Melbourne, VIC
    My alt speed is in kph. Pretty sure that's changable. Rode the motorbike to work today so don't have the manual handy but will double check the MFD settings when I get home.
    Oct 2009
    kensington, nsw
    MY09. It appears in the mfd settings menu where there is
    mfd data
    convenience
    lights & vision
    Language
    Units
    Auto Hold & then
    travel
    then
    service
    factory reset
    Oct 2009
    kensington, nsw
    rocket, am keen to know how you changed the alt speed display to kph as well. Same as pana's mine is also mph.
    Feb 2009
    It's called the "Alternate" display because it shows the opposite to what is on the speedo - it's for when in Europe (kmh) for example you travel to the UK (that uses mph), so you can still have a speedo that works...
    I believe that enabling the "Alt Speed Display" on Aus spec cars with speedos in KMH will only display in MPH. Unless Rocket36's car is special...
