If the roof rails are the same design as those on my Octy (and they most likely are), then be careful pulling of the plastic end caps, if you don't start at the right place (front of front cap, rear of rear cap) it would be easy to break the little locating (plastic) clip on the other end that helps hold them on.
My rails were made of alloy (main body), and plastic (caps that cover the mounting screws), painted silver (original Oz fitting) or black (replacement rails pirated from a NZ model). You might want to get (or make up) new seals that stop water from getting into the body at the mounting points if you are taking the rails off.
If you want to see what it looks like before making any permanent changes you could paint the rails with some water soluble art paint and then just wash it off after you have looked at it (but I wouldn't leave it on too long).
