Results 1 to 6 of 6
Thread: Are Oil Leaks Normal?
    Jan 2007
    Raby NSW
    I have recently purchased a 1998 passat ,125k on the clock with good VW service history.
    Love the car goes geat, handles well and very smooth wth 2.8 v6 engine.
    Had my mechanic pull off the covers and have a good look as the dealer 3 month warranty expires this month.
    He found the following.
    Leaking rocker cover gaskets both sides.
    Rear oil seals at back of engine leaking,
    Cam shaft seals leaking
    Breather hose needed replacing.
    After battling the dealer (non Vw ) they agreed to repair all faults)
    The dealer had just replaced the cam belt prior to delivery so that may explain the rocker cover gaskets, however not the rest.
    Are Leaks at expected intervals normal for this motor? Anything else I should be looking for before the warranty exprires. Thanks
    Aug 2006
    Skye, Victoria
    there is no cam belt on a v6 VW, its a chain. might want to check what they actually did. my vr6 has done 195k and doesnt leak at all (as far as i know)
    Jan 2007
    South Australia
    Welcome any pics ?
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    brackie Guest
    Oil leaks and crankcase pressure
    I'd look a little more deeply. If you have as many seals leaking as this then it would indicate to me that either:
    There's too much crankcase pressure and this could be worn rings
    or
    the crankcase isn't being evacuated properly. In the old days you would look at the PCV valve but today...
    Jul 2005
    98 Passat v6's do have cam belts and do leak from cam seals, rocker cover gaskets, rear main seals and breather pipes which become brittle and crack and like all VW engines and gearboxes weep and leak with a bit a mileage on them.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jan 2007
    Raby NSW
    Thanks for all the replies all useful
    Thanks for all of the replies all very useful. Will check out all the suggestions made. Will have some pics soon
    Will let you know what we find.
Similar Threads
  1. Normal MK1 compared to MK1 Gti
    By intensem1 in forum Mk1 Golf
    Last Post: 16-02-2006, 10:21 PM
