Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: oil leak
    It's a fair drip. Still need to take it somewhere and have it looked at. Could be split oil or something expensive. No way to tell from the photos.
    Rear main seal? Looks like its leaking from between the engine and gearbox.
    Jan 2013
    Brisbane, QLD.
    Yep mate looks like rear main seal. If I were you I would ensure that there are NO leaks further uptop/anywhere else. Then you will need to remove the gearbox to inspect the rear main seal.
    oil leak
    Yep apparently the rear main seal is a pretty fragile/not great design and quite a common failure on the 2.0T engines.
    How The VW 2.0t TSI Rear Main Seal Fails - YouTube
    Mar 2009
    Can I still drive the car though
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by passat08 View Post
    Yes mate, just keep an eye on the oil level. Advisable to get this issue fixed ASAP though.
    Jan 2015
    Melb
    Double post
    Jan 2015
    Melb
    Looks like rear main seal from those photos. Is there any oil above the bell housing? You also need to make sure the breathing system is working properly or the pressure in the crank case can push oil out of the seals. Also make sure the oil level isn't too high.
