Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: New tyres for the R36
    Erskineville, NSW
    Quote Originally Posted by Gipper View Post
    Brad, no I dont yet. The car I used to have so much neg camber was an STi WRX.
    I am not for a moment saying that CRO should be running this amount of camber as each car is different.
    I am actullay glad that CRO has warned the rest of us to keep an eye out on tyre wear. I will certainly be monitoring this closesly and will be getting an alignment done as soon as i pick up the car. I will probably be dialing in some neg camber on the front and rears and then seeing how this effects tyre wear.
    if Doug Heasman reckons that -1F & 0R is right then that's good enough for me.
    I ran -1.75F & -1.5R on my Liberty without issue (and drive conservatively) but the VW has a different suspension setup & therefore different requirements.
    Aug 2006
    melbourne
    Does the Passat allow for front camber adjustments? The GOLF certainly doesn't, of which the Passat is based??????
    Mar 2008
    Melbournes Inner North
    none at all...?!?
    Aug 2006
    melbourne
    only toe AFAIK???? AGain, enlighten me/us if otherwise true...
    Hi Brad, it's ANdrew.
    Feb 2008
    That's correct, you can only adjust toe on the front end.
