Results 1 to 10 of 15
Thread: New tyres for the R36
    Feb 2008
    Yeah I have the 18's with stock rims, you might want to pre-order your PS2's as I know several sizes are out of stock completely. Otherwise you will face the same problem as me.
    Those are the settings I chose for my car to get the most life out of the tyres (front 0 toe, back 0 toe 0 camber). Best to go to a steering and suspension specialist that uses the old school measuring devices, those lasers that Bob Jane and others use are never calibrated very often causing them to be very dodgy.
    If you are in Sydney I can highly recommend Heasemens in Sydenham.
    I reckon I could have got at least 25,000kms out of the tyres if I picked up the wheel alignment issues a lot sooner than I did (12,000kms). As the front is set to 1 degree negative camber rotate the tyres every 5,000 km to keep the inside edges of the fronts from wearing out.
    My driving style is very agressive and I've done thousands of km's on twisty roads throughout country NSW, so you may get even more life out of them
    Aug 2008
    Bentleigh
    If you drive aggressively, then why get rid of the camber at the rear?
    Feb 2008
    So I can get more than 17,000kms out of a set of tyres worth $2400...
    Aug 2008
    Bentleigh
    Quote Originally Posted by Cro View Post
    Surely you could put even .5 degree neg camber on the rear and still keep a fair bit of life in them...?
    I know several enthusiasts that run -1.5F and -1R and still get fantastic life out of the tyres.
    Sep 2008
    Melbourne, Victoria
    Quote Originally Posted by DiMmY View Post
    I used to run -3 deg on the front and -2 on the rear and always got very even wear. I couldnt dial in any more camber on them. My biggest problem was wear on the shoulders. My cornering was always "spirited". Any less camber any i would have rubbed the shoulders off before thr rest of thr tyre showed any wear.
    Erskineville, NSW
    Dimmer & Gippy
    Have you 2 got R36 passats?
    Sep 2008
    Melbourne, Victoria
    Dimmer & Gippy
    Brad, no I dont yet. The car I used to have so much neg camber was an STi WRX.
    I am not for a moment saying that CRO should be running this amount of camber as each car is different.
    I am actullay glad that CRO has warned the rest of us to keep an eye out on tyre wear. I will certainly be monitoring this closesly and will be getting an alignment done as soon as i pick up the car. I will probably be dialing in some neg camber on the front and rears and then seeing how this effects tyre wear.
