Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: New R36 Waitlister ?Biscay vs Icelandic ?Dynaudio
  1. #21
    Apr 2009
    Melbourne, VIC
    1. let it warm up until the auto-choke lowers the revs.
    2. they are CONTRACTUALLY OBLIGATED to fill your order as per the CONTRACT OF SALE. dig your heals in. You should be entitled to a loan car until a car that meets the specs in your contract is delivered. You could take them to court quite easily on this one and WIN! Retrofitting is not the same as factory fitted...
  2. #22
    Feb 2009
    The rough 1st gear is the same even after an hour's drive, so not that it's cold.
    Hmmm.... may have to check this out re my order.
  3. #23
    Apr 2009
    Melbourne, VIC
    hmmm see how it goes it may be tight due to being new. check trans fluid level too.
  4. #24
    Feb 2009
    Also the RNS510 thinks it's in Germany, and is not picking up any local satellites. SO although the Aus maps are loaded, it can't do anything. MAP just shows a blank screen. The Current Location function shows a Latitude NORTH location, so obviously not right. Any ideas on that one?
  5. #25
    Jun 2009
    Around
    Quote Originally Posted by Swallowtail View Post
    Picked mine up.
    Great car, but a couple of issues:
    1. 1st gear is rough from start, feels like a rough clutch. Will see how that goes.
    2. - the biggie - They stuffed up the order, and the car does NOT have Dynaudio. Very disgruntled. They acknowledged that they have stuffed up, and offered me either a discount (to the value of Dynaudio) or a retro-fit. The retro-fit would have to come from a new car that they order and strip the Dynaudio stuff out of as it is not available as parts.
    I'm thinking I should be digging heels in and getting them to give me the new car... am I being unreasonable? What does everyone think? It's clearly on the order forms, and all their documentation.
    Having said that - what a car!!!! So smooth (apart form 1st as above), love the sound of it, well put together, looks HAWT!
    If it is upsetting you I would have them order another car. Its not like your buying a Hyundai Excel worth $14K.
    Retro fit could end up untidy and lots of rattles and squeeks may develop.
  6. #26
    Jun 2009
    Melbourne, VIC
    Thanks everyone for your help & honest opinions again. Will go back to the dealer for a proper audition this time with a favourite CD.... only really tried the standard system during test-drive.
    At least settling on an R36 in the first place was a straightforward decision.... Probably don't need to tell you about a colleague who ordered a BMW and then spent another 2 weeks just wading through the options catalogue!
  7. #27
    Jun 2009
    Melbourne, VIC
    Swallowtail, sorry to hear about your troubles. Surely what has happened to your car is completely unacceptable.... retro-fitting defeats the purpose of ordering the Dynaudio factory fit-out in the first place doesn't it? Who would they be employing to install it and how could they guarantee that everything goes in the right way if they've never done it before. If my car arrives without my only factory option, a sunroof, I definitely won't be letting them cut a hole in the roof!
  8. #28
    Aug 2007
    Adelaide.
    That sucks, Swallowtail. When I ordered my R36 18 months ago I was undecided about Dynaudio after placing the order. At that time, the car was "six to ten months away." After thinking about it for a couple of months I called the dealer to amend the order, only to be told that production of cars for Australia had already started and my car had been built - and the car was here after barely five months!
    My dealer said that they were not prepared to offer the Dynaudio as a retrofit as they couldn't be sure that it could be done to the same standard as one fitted from the factory.
    I'm happy without it, because I didn't order it, but if I had ordered it and it didn't arrive I'd have been very displeased. As it was I missed out on a reversing camera that the factory didn't put on the car because VW Australia forgot to tell them to, and got a large cheque for my troubles.
    R36 =
  9. #29
    Jun 2009
    Swallowtail... firstly, congrats on the new car....sounds like you are getting the dealer shuffle, my friend ordered a Touareg with seat memory from the same dealer that also didnt show up fitted. (Turns out to get the deal they often choose a car as close as possible to the one you want and then apologise later).
    If it was me I would hit them up for a bigger than normal refund of the difference. Its either that or a 4 month wait for a replacement. Unless you are a real audio buff then its not a biggie, the standard stereo is pretty good, and if you listen to MP3's then the quality is already less than CD.
    There is a slight hesitate on take off, I found that turning off the AUTOHOLD fixed the problem, (just remember to use the electronic park brake!!)
    Gone...........R36 Icelandic Gray Wagon
    Specialising in off-topic discussion
  10. #30
    Jun 2009
    Mine had a glitch also on pickup, reset itself to German the first time I used the GPS. I reset the language to English in the MFD and its been all good since then
