Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 111
Thread: New R36 cat-back exhaust
  1. #21
    Feb 2009
    Quote Originally Posted by Autopia View Post
    Surely you weren't expecting a huge power increase?
    The price is actually reasonable for a custom made, low production run system.
    It may be reasonable for a custom made low production run system, I am sure it probably is. But it's a huge amount of money to pay for minimal gain other than a better exhaust note.
    I realise it's naturally aspirated as opposed to FI, which is a whole new world for me, but it puts the 40KW gain I got for $1300 on my Mazda into perspective (190KW > 230)...
    <shrugs> you pays your money you takes your choices... doesn't seem like a good value buy to me.
  2. #22
    Apr 2008
    QLD
    Quote Originally Posted by GT3 View Post
    Thanks for the feedback so far guys.
    The exhaust is locally produced, hand-made from 304 stainless steel with mandrel bends and is fully TIG welded. The mufflers and resonators are made using steel wool packing as opposed to fiberglass used in cheaper systems. It’s a high quality system as you can see from the photos below.
    These systems will need to retail for $3,395 incl GST for production to be viable. Based on the feedback provided here (and elsewhere), we will determine whether these systems will go into production or not.
    In terms of performance, testing to date has shown a gain of up to 8kw atw on a 4wd chassis dyno. That’s a great gain for a cat-back system on a normally aspirated car.
    GT3, if I am based in Bris, do you guys have an affliliated fitter I can use? So if I purchase the exhaust, you send it to your affiliated fitter to install in my car?
    Also, could you do a quad pipe at the tip instead?
  3. #23
    Apr 2008
    QLD
    Quote Originally Posted by Swallowtail View Post
    But was your exhaust a stainless one? gotta compare apples to apples here...sure my previous exhaust system was cheaper too but so was the material.
    Also, a cat back system on an already relatively highly tuned naturally aspirated engine is never going to gain any significant power/torque increase.
  4. #24
    Feb 2009
    Quote Originally Posted by theplanner View Post
    Wasn't exhaust at all. It was an engine management system. No way you'd get 20+% gain out of only an exhaust system even on a turbo car... (EDIT - at least not on a modern car with a half decent tuned exhaust to start with. A turbo back exhaust on the Mazdas gives about 10 to 15KW, or 5 - 8%).
    I have no problems with a nice exhaust, I love the look of stainless, and I love the nice sound, but in terms of bang for buck from a performance perspective it's a very expensive way to buy KW.
    LOL, I haven't even got the car yet. But I doubt very much if a $3 1/2 grand exhaust will be on the shopping list - to each their own though...
  5. #25
    Apr 2008
    QLD
    Yes, I agree too from a bang for buck in performance perspective.
    I susposed the question then is, is the sound worth the money? Because the standard exhaust is quite good quality already (at least from what I can see).
    But I wonder if this exhaust would provide a slight power gain but resulting in peak torque arriving later in the rpm.
  6. #26
    Jun 2007
    Quote Originally Posted by zsolt_downunder View Post
    ..was there any benefits in the torque curve or any increase in torque?
    This was our test run without the centre resonator. In order to get sound to aceptable levels, we had to sacrifrice a few kw atw - but we think we got the balance right. Note: losses through the drive train (kw atw) are significantly higher for 4wds when measured on a dyno.
    Systems can be delivered and installed in all major cities for those who have asked.
  7. #27
    Jan 2009
    Pakenham
    Maybe I'm reading the info incorrectly but does the readout indicate a peak of 539Nm??
    It's only 350Nm stock so I'm obviously misunderstanding something here. Can someone please clarify?
  8. #28
    Feb 2009
    That's "normal"... in my experience dynos' torque readings are always miles high. Not sure why though.... maybe someone else can enlighten on that score.
  9. #29
    Feb 2008
    Sydney, Australia
    That is an "at the wheels" torque figure on the graph, rather than "at the flywheel" figure which is what the VW quoted figure is. Suffice to say that the torque is higher by about 30-40Nm right across the range, so about a 8% increase which is not to be sneezed at.
  10. #30
    Jun 2007
    Chassis dynoes can't measure torque accurately, instead they apply a calculation of kw/hp vs rpms to give an indicative figure. The only way to measure torque accurately is with an engine dyno.
