Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 111
Thread: New R36 cat-back exhaust
  1. #31
    Apr 2009
    Sydney Australia
    Sounds great!!
    I was wondering how to keep the lovely burble at idle, while the choke is running going for the rest of the drive. Now we have an answer! How much and can we do a twin turbo setup?
    Billcat: R36 09 Biscay blue sedan, sunroof, satnav, bluetooth, Ipod connection and tints - Love that car!!
  2. #32
    Jan 2009
    Pakenham
    Quote Originally Posted by Lance B View Post
    That is an "at the wheels" torque figure on the graph, rather than "at the flywheel" figure which is what the VW quoted figure is. Suffice to say that the torque is higher by about 30-40Nm right across the range, so about a 8% increase which is not to be sneezed at.
    Sorry but the "at the wheels" power and torque figures are always lower than flywheel readings not higher.
    So if the R36 has 350Nm (as stated by VW) at the flywheel then the "at the wheels" measurement should be less due to the transmission and driveline.
    It's been explained by the dealer anyway.
  3. #33
    Aug 2008
    Bentleigh
    Quote Originally Posted by Autopia View Post
    Power will always be lower at the wheels, torque no.
    Torque depends on gearing, you could get a torque reading a of over a 1000Nm with the right gearing and diff ratios.
  4. #34
    Mar 2009
    Melbourne, Aus
    Warning - Science content
    (1) Power = torque * rotational speed
    ie (Watts) = (N.m) x (radians per second)
    (2) You can have torque without power (ie stalled electric motor)
    (3) transmission efficiency always less than 100%
    so you will always lose power progressively thru the drivetrain
    from the crankshaft to the wheels
    (4) For manual (ie no slip) rotational speed ratios fixed, so
    (5) Power losses appear as torque losses, superimposed on (1)
    QED if you do the maths on the gear ratios
  5. #35
    Mar 2008
    Melbournes Inner North
    yeah, but how good does it sound....
  6. #36
    Feb 2008
    Sydney, Australia
    NO!!! Power will be lower, but torque is higher due to the multiplying effect.
    Here is an example:
    http://www.car-videos.net/articles/h...wer_torque.asp
    Flywheel Torque in this example above in 1st gear is 154.7ft-lbs and wheel torque is 1,735ft-lbs!!!
    Flywheel Torque in this example above in 5th gear is 154.7ft-lbs and wheel torque is 382ft-lbs!
    This is why you can get a car moving in 1st gear quicker than in 5th gear due to the multiplying effect of torque.
  7. #37
    Apr 2008
    Quote Originally Posted by GT3 View Post
    We've completed development of our R36 cat-back exhaust - should be ready for release soon. Here's a sneak preview of what it sounds like (goes pretty good with the tune too ). ..more info will be available once all testing is complete.
    See the video here
    Wow. I think that must be the best sounding V6 I've ever heards. I can't stop listening to it
    2000 Mk IV GTI
  8. #38
    Mar 2009
    Melbourne CBD
    My R36 (vroom)
    Hey guys i am loving the new cat-back on my R36... The boys down at Evolve-Technik have done a brilliant job.. The new exhaust and tuned ECU definitely gives the car more grunt.. Stock BMW 335i's are given a run for their money.. Next up is H&R height adjustable coil overs and H&R adjustable anti-sway bars.
    ALFIE
    Nissan Elgrand E50, Polo GTI and Evo 6RS Track car
  9. #39
    Jan 2009
    Pakenham
    Quote Originally Posted by Black R36 Sedan 09(alfie) View Post
    Thanks for the feedback.
    ECU tune, cat-back exhaust, H&R coil overs and sway bars....spend spend spend. Way to go.
    Where are you getting the H&R gear from?
  10. #40
    Dec 2008
    Melbourne, VIC
    Good luck with the rest of your tuning/modification endeavors and keep us posted.
