Take it back to the dealer and get them to check it out.
Have never had any wind issues on either of our B6 Sedans.
maybe the wipers
My 7 year old b6 wagon id a quiet as a mouse could the have done something to the window frames when they did the tinting? Perhaps take back to dealer and compare to another wagon
B6 Passat Wagon No KESSY
Interestingly today I was out in the car and after having it parked in the sun for about 15 mins I got back in and when it started up there was a rather piercing whistle.
I tracked it to an air vent as I had air on full cold and the l/hand centre dash vent was almost closed and I think that caused it . When I backed the fan off and opened the vent it no longer did it.
Yeah, I'll concur with OilBurna. My 4 year old B7 Wagon has never made a sound apart from when I have the racks on.
2011 B7 Passat Highline Wagon TDI. I Tinted the Windows
If you can duplicate problem at a lower road speed, could indicate problem not due air pressure on panels.
First, monitor oil temperature to ensure engine fully warmed up
Take note of tachometer reading at "122"
Manually select second gear from top ( Position 6 instead of 7)
Try driving about 10% below and above tacho reading.
Also try reasonably firm acceleration through this test area.
MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
Try same revs in different gears Should tell if its a harmonic issue related to driveline or as said above different revs at the same speed
