Results 11 to 20 of 21
Thread: New Passat (2 days old) - wind noise issues. Not happy!
    Feb 2014
    Take it back to the dealer and get them to check it out.
    Have never had any wind issues on either of our B6 Sedans.
    Nov 2014
    Yes - resonance - that's the word I was after, and exactly what it feels like. I didn't have any extra options (except window tinting and protection pack) just the basic model.
    Quote Originally Posted by Cossor View Post
    Hum and wind noise could be related if a body panel is incorrectly fitted, and at a certain speed vibrates (At resonance)
    In which case said body panel causing wind noise also.
    Another possibility is incorrectly fitted exhaust system, again hitting a resonant spot
    By the way, did you consider the adaptive suspension option?
    Nov 2014
    Will definitely have it checked out - what I'm getting from these replies is that it isn't normal, which is what I wanted to confirm. Having never owned a VW I wasn't sure, but I was very surprised when I got up to 100k and heard it.
    Quote Originally Posted by nermal View Post
    Nov 2014
    Good to know that that this is definitely not normal. I'm pretty sure mine is coming from the windscreen - I'll be asking them to check the seal.
    Quote Originally Posted by BFPO40 View Post
    My brand new Golf also has excessive wind noise from the driver door, it sounds like the window is open by a few mm. This is my forth Mk7 Golf over the last year and the previous three were amazingly quiet, the low cabin noise is one of the features I liked about the Mk7 and why my Mk7 GTI had a soundaktor to compensate.
    My previous experience of the Mk7 tells me that it is not caused by the side mirrors or external design features and it is definitely a fault. - I've traced it to the outer door seals not making an effective seal, air is passing through but not penetrating the inner door seal - it does however let outside noise in including wind.
    Visually the seals look perfect, the door may need adjusting to close tighter or seals replaced - yet to be determined pending a dealership visit.
    Hope this helps.
    Jul 2013
    Hills District
    maybe the wipers
    Dec 2007
    ivanhoe vic
    My 7 year old b6 wagon id a quiet as a mouse could the have done something to the window frames when they did the tinting? Perhaps take back to dealer and compare to another wagon
    B6 Passat Wagon No KESSY
    Pacific Paradise QLD
    Interestingly today I was out in the car and after having it parked in the sun for about 15 mins I got back in and when it started up there was a rather piercing whistle.
    I tracked it to an air vent as I had air on full cold and the l/hand centre dash vent was almost closed and I think that caused it . When I backed the fan off and opened the vent it no longer did it.
    Aug 2012
    Churchill
    Yeah, I'll concur with OilBurna. My 4 year old B7 Wagon has never made a sound apart from when I have the racks on.
    2011 B7 Passat Highline Wagon TDI. I Tinted the Windows
    May 2010
    Bundanoon NSW
    Quote Originally Posted by Westy View Post
    The second issue - that loud hum at 122 is like a vibration that runs through the whole chassis, but has a "pitch" - like I could hum it. It is only at an exact speed, ease off or speed up by 2km/hr and it goes away. That one isn't such an issue because I don't drive at 120km/hr (much ...) but it says to me there is something not quite right. I will have the tyres checked at the 1000km checkup.
    Thanks for the quick response
    If you can duplicate problem at a lower road speed, could indicate problem not due air pressure on panels.
    First, monitor oil temperature to ensure engine fully warmed up
    Take note of tachometer reading at "122"
    Manually select second gear from top ( Position 6 instead of 7)
    Try driving about 10% below and above tacho reading.
    Also try reasonably firm acceleration through this test area.
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
    Try same revs in different gears Should tell if its a harmonic issue related to driveline or as said above different revs at the same speed
