Results 1 to 6 of 6
Thread: New B7 TDI Passat morning starts
    Hello I have new B7 TDI passat, had it for almost a month.
    Almost every morning car has problem starting up. I depress the brake pedal, put the key in, press on it and ... nothing. Eventually after pressing the key 3-5 time it would start. sometimes engine stops when you stop pressing on the key.
    Spoke to the dealer and they said it's normal (they explain that it has to build pressure in fuel line before car starts). As it's my first diesel and first car with push to start feature, I'm not sure what is normal what is not.
    Jun 2011
    QLD
    Damn! I am about to get the TDI as well!
    Perhaps it is something to do with the bluemotion start/stop technology? When I test drove the dealer say the engine must warm up before this will kick in. Have you try to disable that and see if it makes difference?
    I have a Volvo XC60 diesel, never had problem starting.
    Oct 2010
    Melbourne, VIC
    Sounds like a crock to me. We have a VW with a PD diesel and another with a CR diesel and neither need more than minimal cranking to start.
    Start a thread in the diesel section about this as there are many with far more diesel experience than me.
    Feb 2010
    Canberra
    Quote Originally Posted by russellwrx View Post
    Keep your foot depressed and wait for it to start.. I have one as a drive car and I live in cold canberra.. sometimes when you rush the car does not see you having your foot firm on the brake to trigger. there will be a pause from when you push the starter to when it chugs up.. it is warming it self..
    Phillip Fairhall
    Brand Manager
    Rolfe Renault / Audi Centre Canberra
    Melrose Drive Phillip ACT
    Dec 2009
    ringwood vic
    This must be a new stop/start model thing, my 17 month old CC TDI never has a problem simply firing up.
    May 2011
    Melbourne, Victoria
    russelwrx, I visited Werribee VW this afternoon and while booking in for test drives of the TSI and TDI I mentioned your post to the salesperson. She was curious too and immediately said let's try it on a B7 TDI wagon that hadn't been turned on all day. She depressed the brake pedal, inserted the key fob into the dash and the car started instantly. She said there shouldn't be more than a maximum 5 to 10 second delay. Just be sure as Phillip has mentioned to press the brake pedal firmly, hold it and insert the key fob securely. If your TDI still doesn't respond as suggested, do get it checked out by your dealer.
