Originally Posted by
martinp
Howdy,
New to forum (OK have read it a bit over the years).
I am hoping to pick up my new black wagon next week.
Can some one give me an idea other than the usual journo's idea of......
Fuel use - city/country/mixed.
Does the dodgey injector issue affect these ones?
Best fuel to use?
Anything else?
I used to have a 2000 1.6 l Golf but sold it and bought a 307 HDI wagon (VW at that stage refused to import anything similar to it). It was a good car as I did 280,00kms in it and averaged 6.3 l/100km over its life.
I always used (mostly) BP diesel in it as it went a bit further and did not foam up as much as other types of fuel. Also BP is the only retailer who stated the cetane rating of their fuel as being 51 (shell states 49).
I would like a bit of feedback if anyone has had any good bad experiences etc.
I mainly do long highway drives and was looking to go up one size in car just for comfort and the Passat looks to be the winner this time round.
Will keep you posted on how my new wheels go once they roll out the door.
Martin.
Great car you are getting there...
To assist with a couple of the questions, not to say that you wont have issues with a CR engine, the injector issue is a know issue in PD engines for now.
BP fuel could be the way to go if you are already comfortable with it...
I myself use BP Ultimate Diesel and only go to the same servo and use the same bowser and always ask for a reciept.
I have a tick over 8000kms since new on mine and I am averaging a combined 6.3L/100km (as per MFD), not sure how accurate that is, but hey that is what it says. The lowest average consumption I have achieved is 3.9L/100km with 4 onboard and luggage heading down to Grafton last weekend.
As for maxim talking about the fans, I have had this issue too.
I had it on my 2.0T FSI Passat and it would only happen when hot, thus fans keep running.
What I have discovered is that with the TDI's the fans run if you have had them on for a short time, been driving fairly casual and the car might be doing a forced reg of the DPF. In fact I am very confident that you will find that being the issue, innfact it is not an issue it is just the car do its thing...
As for the Climatronic, it has two AUTO function (one low fan speed / one high fan speed), maybe yours is on the high fan speed.
Unlike others on this forum who seem to turn the Climatronic system on and off all the time.
Mine is always on AUTO (low) / 23 degrees and works a charm. The fan speed will go up when it is hot to cool the car, once at temp it will slow down to generally 2 bars on the fan speed.
I hope this little bit of info helps you...
