Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
Thread: New 125 highline on the way, questions questons questions???
  1. #51
    Dec 2007
    ivanhoe vic
    Valvoline Synpower had been $55 or so at Repco
    B6 Passat Wagon No KESSY
  2. #52
    Aug 2012
    Perth WA
    Quote Originally Posted by dinot81 View Post
    I mentioned in another section that would prefer to change Castrol FST twice per year than once with Liqui Moly. I change my oil between services once, end up with new engine oil every 6 months and about 6,000 kms. Just prefer it that way.
    +1
    Obviously all oils that are VW 504/507 approved meet the minimum specification and will do the job, but i agree dinot81, oil is cheap insurance and that changing it twice as often, using the cheapest approved oil is better than changing it once with the most expensive.
    Just as a comparison, LandRover Disco 4 TDI has 26000km oil change intervals. Way too long IMHO.
  3. #53
    Dec 2015
    Newcastle NSW
    Cheers guys I'll buy the castrol!
    I have a heap of castrol edge 5W30 A3/B4 that I bought on sale for use in my petrol cars. I'll exchange one of those at SCA for the castrol edge 5W30 DPF VW 504/507 oil (I'll have to chuck in an extra $5.07 as the DPF version is more expensive)
    Castrol Edge Diesel DPF Engine Oil - 5W-30, 5 Litre - Supercheap Auto Australia
    FWIW I have seen the penrite enviro on sale at SCA currently for $65
    Penrite Enviro+ Engine Oil - 5W-30, 5 Litre - Supercheap Auto Australia (this promo ends 16th jan 2016)
  4. #54
    Feb 2015
    Here is bit of a comparison between Castrol EDGE FST, Castrol EDGE Professional LongLife III (what VW fills at service and some overcharge if you buy from them) and Penrite Enviro+. These are suitable for DPF:
    Castrol EDGE FST 5W-30
    Castrol EDGE Professional LongLife III 5W-30
    Penrite Enviro+ 5W-30
    You will see that the two Castrol oils are identical in specs with Penrite Enviro+ having slightly more Ash but should not be an issue. Wait for specials and buy bulk. As long as they remained sealed, can be stored for long time. I paid $55 for Castrol EDGE FST 5W-30 and still have another left. Plus can fill up into dad's Golf (petrol engine) as well. They come from factory with Castrol oils and I prefer to stick to same brand in this case. You should have Castrol written on the oil cap on the engine.
    Hope this helps
    Regards
    Attached Thumbnails Attached Thumbnails New 125 highline on the way, questions questons questions???-castrol-edge-fst-jpg   New 125 highline on the way, questions questons questions???-castrol-edge-professional-longlife-iii-jpg
    New 125 highline on the way, questions questons questions???-penrite-enviro-jpg
    MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
  5. #55
    Dec 2015
    Newcastle NSW
    Hope this helps
    Regards
    Cheers and thanks for taking the time for the informative reply!
    Yup bugger all differences between the specs of the castroland penrite, except the castrol can be had for dirt cheap on bathurst SCA annual sales, or at times they have a random blowout special on castrol edge (I got about 40L worth for $29.99 for each 5L edge 5W30 A3/B4 about 2 years ago!!)
  6. #56
    Feb 2015
    Just be careful that A3 / B4 is not recommended for TDI engines especially DPF. That's different spec of oil. Lot cheaper than the FST for DPF diesel.
    Sent from my HTC_PN071 using Tapatalk
  7. #57
    Feb 2015
    In addition to above, Castrol EDGE A3/B4 has different classification:
    • Petrol : SL*, (SJ, SH and all superseded classifications):
    • Diesel : CF
    • ACEA A3/B4, High performance shear stable petrol/diesel engine oil
    • BMW Longlife-01
    • VW 502 00/ 505 00 (NOT 504/507 which is your longlife and VW recommended oil)
    • MB-Approval 229.3/ 229
    Did you get this bottle???
    Here are the specs for this oil:
    You will notice that the amount of Ash is almost twice as high as the other ones mentioned above, very bad for DPF and the actual oil itself as will collect more dirt (Ash / Sulphate) inside the engine. More sulphate, more smoke, more soot in your DPF (will clog-up faster). My advice is stay away from this oil in TDI engines.
    This one would be the safest option.
    Regards
    Dino
    Attached Thumbnails Attached Thumbnails New 125 highline on the way, questions questons questions???-castrol-edge-a3b4-jpg   New 125 highline on the way, questions questons questions???-untitled1-jpg
    New 125 highline on the way, questions questons questions???-3373545_20edge-5w30_205l-jpg
  8. #58
    Dec 2015
    Newcastle NSW
    Yes I got the castrol edge DPF!
    I got sidetracked writing my post, I bought a heap on sale and had about 20L worth of the A3/B4 oil, I took it to SCA today and exchanged 10L for the edge DPF!
    Came in handy!
    Bloody ryco, they wanted $52 for an engine oil filter... Get stuffed, I went to my local VW dealer and they were around $24, and the supposedly one time use sump plug was $5 odd.
    Cant believe the Chermans didnt design the car with a F&R central jack point... So you have to jack the car from the side and put your cars stands under the front subrame... Crazy... Found this pic:
    The V's in my jack stands didnt fit the control arm very well, so I placed a heap of timber under the sills (just in case...)
    I might invest in a oil extraction pump or some ramps next time to make things easier... And to buy a fumoto oil drain valve to save buying new sump plugs every time i do an oil change...
    My BMW is much better has a great central jack point, trap door in the plastic undertray to access the sump plug (saves removing the whole entire tray)
  9. #59
    Aug 2011
    Rokeby, Vic
    Hi all I got the thermostat replaced last week it cost $615! Wow. But yes they had to remove oil filter and housing plus oil cooler then alternator then could get the thermostat out and reverse to replace it all with new gaskets/seals etc and fluids. Most of the cost was labor.
    ABS fault was not fixed as it has to be replaced and re-mapped by VW using their secret codes. So off to the VW dealer next week for them to start scratching their heads as to what is wrong with it.
    I think it will be expensive as they quoted $160 per hour for diagnostics only. (Not bad for a plug in readout of faults).
    I shall report back on the ABS progress. Sad face sad face sad face.
  10. #60
    Aug 2011
    Rokeby, Vic
    Hi all, I just replaced the rear ABS sensors and hey presto ABS fault gone (well it has done 300 metres). I hope it stays fixed but am going to give it a week or two before I trust it again.
    It is up for sale at the end of March if anyone is looking for a used Passat wagon.
