Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Need your opinion please
  1. #21
    May 2009
    Canberra
    I will be checking the car.My issues is I cant make up my mind which car to go. either way I'm getting a good car and a good buy.
    2009 Tiguan TDI and 2007 Passat TDI
  2. #22
    Jan 2013
    Let me know what you decided. Good luck just noteenon light with proper auto levelling installation cost around 3.000 au$...i do not have and after while i decide that not wort to go...only update i done was rns510 e series and premium bluetooth (with voice control) installation. Everything done by vw and i am very happy
    Sent from my GT-I9305 using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
  3. #23
    May 2009
    Canberra
    thanks mate. will do. thanks for your feed back
  4. #24
    May 2010
    Melbourne, VIC
    Quote Originally Posted by revhead1016 View Post
    And I also saw this one. Comparing the two. Which one is better buy?
    A couple of items:
    - The first car appears to be fitted with an aftermarket head unit (and probably an aftermarket RVC as well).
    - The second car has the older RNS500 satnav unit, which is not MP3 compatible (according to the MY08 spec sheet that I have) - the 'standard' 6-stack head unit is MP3 compatible.
    - The second has twice the mileage of the first, but seems to be more optioned up - satnav, electric heated memory seats, sunroof, bluetooth...
    how the hell did you know that this car has Xenon light. also are you saying the one in Sydney doesn't have that light.
    Neither of the two cars you listed have the factory bi-xenon headlights.
    You have to look carefully, but there is a difference. The non-bixenon cars have a separate high beam reflector, while the bi-xenon cars just have the park light in that position. If you look between the projector lens and the park light section on the Passats fitted with bi-xenon headlights, you'll see the angled reflector for the static cornering lights.
    http://liveimages.carsales.com.au/ca...Pad&width=1050
    The rest of the car: 2008 Volkswagen Passat Type 3C R36 MY08 Direct-Shift Gearbox 4-Motion
  5. #25
    Pacific Paradise QLD
    Here is what the codes in the handbook with the original car decode to. NO XENONS MENTIONED, NO SATNAV EITHER.
    Satnav code is 8AY Mine has Xenons but they are not mentioned in option codes but may be in the car codes which are MSU LA8X NV
    They came as part of the driving package
    Found my Passat codes and Gas discharge headlights are PR number 8IM family is HSW
    X8C = National sales program Australia
    B0R = Component parts set, complying with vehicle type for Australia, various parts
    CA5 = Alloy wheels 7.5J x 17
    G1A = 6-speed automatic transmission
    HK0 = Tires 235/45 R17 97W x1
    J0L = Battery 340 A (70 Ah)
    D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
    V0A = Tires w/o specification of tire brand
    1AT = Electronic stabilization program (ESP)
    1G3 = Alloy spare wheel with original equipment tires
    2ZB = Leather multi-function steering wheel
    5RV = Right exterior mirror: aspherical
    5SJ = Left exterior mirror: convex
    TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B
    3S0 = Without roof rails/roof load rack
    8T2 = Cruise control system (CCS) electronic
    0G2 = Selector lever
    8YM = Radio with CD player (high-end)
    8GU = Alternator 140 A
    1LH = Disc brakes, front
    L30 = Suspension range 30 installation control only, no requirement forecast
    0YD = Weight range 4 installation control only, no requirement forecast
    G07 = Front shock absorption
    0GG = Emission standard EU4
  6. #26
    May 2009
    Canberra
    Need your opinion please-image-jpg
    Hi all I'm a new passat Owner. Proudly owned a 2007 passat tdi
  7. #27
    Jan 2013
    Nice car..congrats
