Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Need some advice B6 PASSAT owner.
    Unkonwn_User Guest
    Question Need some advice B6 PASSAT owner.
    Unkonwn_User Guest
    I reckon you should run around in 2nd for a week and clean out the exhaust that way.
    I suspect you are right and there's a good amount of soot built up in the exhaust. Lots of cars emit a puff of black when you first open them up, due to the richening of the mixture.
    I wouldn't worry about it breaking if you tune it, there's thousands of tuned 2 litres on the planet. There's a lot more tuners out there than APR so do some more research on that subject.
    Cleaning out the intake is a pretty time consuming job, a grand seems a bit heavy. There's no other way to do it though.
    Unkonwn_User Guest
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by g0harvey View Post
    1) on full acceleration i noticed theres big black plumes of smoke behind me. Especially when i first did this. I assumed the previous owner never gave it much of a boot and it has gotten slightly better.
    There is nothing unusual about this at all - however it's more common on tuned cars
    I had my ECU flashed at 14,000km and the car has blown this very large cloud of fuel haze ever since
    It's more noticeable if you've been quietly driving for some time and then floor it.
    I know ~5 people with Octavia's (most are tuned) and they all do it
    The stock car does it the least
    Just check your exhaust exit, put your finger in and touch the side
    If it's dry soot you are fine - if it's wet slime your engine is tired and has some blow by (needs a rebuild)
    He advised me this will cost $1000 to walnut blast clean.... wtf?? I did some research and found out its common on Direct Injection engines to have a carbon build up.. Should i get this done?
    Direct injection into the combustion chamber means there is no fuel washing over the inlet valves
    Hence they can and do get carbon build up for sure
    At that mileage, probably a good idea to have it cleaned,
    but there are other more cost effect methods
    Mountain bike Mike has cleaned the inlet valves himself and Brad explained another technique
    Read about it here: MountainBikeMike's Skodaru
    2) The cars now on 120000k's after a mega road trip. Im toying with the idea of doing an APR stage I chip or something similar. This boasts 180kw power. Im concerned about doing it at these kilometres. I don't want the car to be something to redline all the time, but would be nice to compensate for the weight a little more.
    As long as the engine is not blowing oil (you could do a compression test) go for it
    The APR flash really puts some life into the engine and makes over taking a breeze
    APR Stage 1, the top end is worse than stock, Stage 2 is the ducks guts but you need the down pipe also
    3) A friend was telling me installing a down pipe might be a good idea to lean out the fuel (by having less restrictions near the turbo) to prevent the carbon build up issue escalating (he's done this on his mk5 gti).
    Absolute nonsense - exhaust restriction does not have any effect on fuel supply!
    The fuel is controlled by a closed loop system,
    the ECU is watching the O2 sensor and controlling the fuel supply accordingly.
    At full throttle a lot of cars go open loop and the ECU gives the fuel directly from a predefined map.
    When we go stage 2 we use a different down pipe to get a bit more gas flow, mainly from the hi flow cat
    The stock cat is 800 cell - the hi flow cat has 200 cells
    This just enables better flow (does not alter the fuel supply)
    Our Octavia's have the same 2L TFSI and TSI engines used in the Passat range
    The performance down pipe we use is a Jetta upgrade item
    Dec 2012
    asked if it has a noticeable rougher idle etc
    Go to Repco and buy a bottle of fuel injector cleaner - Nulon/Repco/LiquiMolly
    There is a normal version and a heavy duty version
    Fill the tank with fuel - put the correct dosage into the tank
    (If using the heavy duty cleaner don't do a lot of hard driving at full throttle)
    Once the tank has been consumed you should notice the idle is now smoother
    Do this every 4 or 6 months
    Mar 2009
    Hey mate I have a 2008 passat have stage 1 apr, carbonio air filter and thing goes hard for a wagon next step is dump pipe which in process doing. Only issue and worry I have is the gearbox if it can hold that much power as I don't have the dsg.
    Dec 2012
    The manual gearbox is strong enough - no question about that
    It's the small DSG clutches that are the weak link, the manual clutch has no issue
    (APR Stage 2 is just over the torque capability of the DSG clutch but I'm not having any problems)
    Mar 2009
    I don't have the manual gear box I have the tiptronic but non dsg. You got any pics your ride Martin
    Dec 2012
    Hmmm,
    Numerous cars are sold as "Tiptronic" but they are not the real Tiptronic,
    They are just a torque converter auto with a little bit of electronic control
    I think the Passat "Tiptronic" is actually a ZF auto with torque converter
    Here is my humble Octavia
    I've done some carbon wrapping of the dash
