Originally Posted by
R36VW
BTW Just use a usb drive on the MDI its more convenient than dragging DVD's out to the car.
Oooh, I'm intrigued. How does this work? Do you mean the SD slot, or is there a separate USB adapter somewhere I can use?
BTW - my RNS-510 is an older 'A' model with a limited 2G SD card capacity (currently running firmware 1200). I tried upgrading the firmware a while back and 'bricked' it. The dealer said it was toast, but luckily Martin at JKU.com.au was able to revive it with some of his RNS magic =)
