Much speculation and opinion but so far no facts.
passatpout, since I have essentially the same car as yours (including a slightly clunky DSG) I thought I'd give it a try.
First let's go through some thought experiments. This is all based on using the DSG in manual mode (NOT D or S).
50 km/h in 3rd gear is just about 2,200 rpm, give or take. 75 km/h will be about 3,300 rpm, give or take. That is well below the electronically controlled rev limit of 4,500 rpm for the 125 TDI. The engine spins quite happily to that limit when accelerating, and the DSG then automatically shifts up a gear. Not the most efficient way to accelerate but possible.
This morning, doing 80 km/h (GPS, not speedo) in 4th gear with warm engine and gearbox (I would like to think) I pulled back the DSG lever, and 3rd gear was engaged very smoothly thanks to the ECU matching engine revs to the speed perfectly. Ended up doing about 3,500 rpm. No sweat.
I have, and I hate to admit this, inadvertently selected 1st gear instead of 3rd when accelerating, and have seen in excess of 4,000 rpms.
I would think that, as long as the selection does not result in rpms exceeding the rev limit the DSG should simply obey and shift down, for whatever reason the driver chooses to do this.
Anyway, hope this helps.
Regards,
Michael
MY08 125 kW TDI Wagon
PE Black, Sunroof, iPod
MY09 CR TDI Eos 6-speed manual
Candy White, black leather, Sports suspension with 18" Chicagos
