Front brake rotors and pads, at 60k, probably
At that price you could have had some upgraded aftermarket rotors
The battery looks expensive
So I booked in my 2012 Passat TDI for it's 60k service, after getting an estimate from my local dealer service department (VW Waverly) of about $1200. A few hours after checking the car in I get a call stating stating I need new front discs and pads $757, new battery $571 and they suggested an aircon clean $99, all in addition to the major servicing cost of $1200!
Is this situation normal?
Outrageously overpriced battery. $150-200 would get you a good quality battery from somewhere like Battery World or similar. I had to replace the battery in my 2010 GTI Golf about 18 months ago and it cost me $170.
As mentioned by Martin, you could have sourced aftermarket brake disks and pads for around half that price, but then you'd have to either install them yourself or pay a mechanic to do it. Would have been a good opportunity to replace the pads with an aftermarket low dust option too.
But that's how dealerships operate - you are paying top dollar for both parts and labour. Perhaps find yourself a reputable independant VW specialist (there are several scattered around Melb) and enjoy both the savings and the increased quality of work.
may be they are selling u entry level lithium car battery?
$300 will get u agm battery.
MINI Cooper S Clubman - FWD
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
Well mine has the expensive Varta for stop start and Battery World quoted me $800
Whether its true or not I dont know Just reporting the fact of what I was told. My 60,000k service was only a bit over $800 and I supplied the engine oil myself The DSG was done as well
Brakes etc didnt need done as car had only done 20,000 at the time but 4 years old
Wow brakes at 60,000kms is bad. I've done nearly 160,000 kms and still original.
I would be getting a second opinion. Try volkshome in thomastown. They are very reasonable.
I have not been to a dealer for a while now as the basic service was getting to 600-900$$ so I now get them done for just over $300.
Regarding the battery, have a look on eBay, found someone in QLD selling Varta Silverline AGM for $397 incl postage. 760 CCA starting power. I think anything above that price is way too much.
Sent from my HTC_PN071 using Tapatalk
MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
