Results 11 to 20 of 26
Thread: Machining OEM/Stock R36 Rotors
    Nov 2012
    Perth, WA
    I recently upgraded all my brakes from GSL about 6 months ago. I went with DBA T3 DBA42808S for the front and DBA T2 for the rear with Remsa pads all around. I think all up it was under $1000 and I was quoted around $1250 for OEM. I would say that the Remsa pads are average when cold (middle of the night etc) but warm up pretty quick and bite well then. They are really really bad on dust, probably worse than stock and if I hadnt just got them i would change them. What made it even more noticeable was when I plasti dipped my rims black and I had a dust coating over it. GSL also had a EOFY sale in June on for the same setup and it was only about $600 i think.
    R36
    Nov 2010
    Good to hear basic. Thanks for the heads up
    Jul 2013
    Hills District
    Quote Originally Posted by basic View Post
    I have stocked up the exactly rotors from GSL. Thanks for the heads up. I will do more research on pads when I need to put new rotors and pads on. So far it looks like the ATE ceramic is the way to go.
    Oct 2012
    Melbourne, Victoria
    Yeah, I think I'm going to follow suit.
    For anyone else who's interested, I've linked the rotors below.
    Fronts: DBA42808S
    Rears: DBA2809S
    To the guys with the ATEs, where'd you source them from? Had a quick look around, but wasn't able to find anything solid regarding pricing.
    Jul 2010
    bracken ridge qld
    this is who i got mine from.first class service and very helpful.
    cheers
    warrick
    Everything You Need to Know About ATE Ceramic Brake Pads - Bavaria Motor Tuning Service, Brendale
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Oct 2012
    Melbourne, Victoria
    Quote Originally Posted by warrick View Post
    cheers
    warrick
    Thanks for the quick response Warrick. I'll have a look-see.
    Oct 2012
    Melbourne, Victoria
    Hi again guys,
    Finally received my rotors and pads today (ended up going with QFM because I was a bit skeptical over the ceramics bite. Might give it a go next time).
    One thing I completely overlooked was the brake wear sensors, which don't come with the pads.
    Am I able to re-use the existing sensors, or am I better off getting a set from VW? From what I recall reading, I believe the R36s only have sensors on the front?
    If someone more experienced would be able to cast their opinion, that'd be awesome.
    Quote Originally Posted by MrWolf View Post
    Hi again guys,
    Are I able to re-use the existing sensors, or am I better off getting a set from VW? From what I recall reading, I believe the R36s only have sensors on the front?
    The sensor is embedded in the pad so you would have to be pretty motivated to swap them over. Assuming that you are the kind of guy to look at your brakes more than every 15k, you can cut the wires off the old pads and electrically short them out, to stop the warning light coming on.
    Jul 2010
    bracken ridge qld
    on my cc the sensor was only on the passenger front side.one of the reasons i didnt get the QFM was because they didnt have the sensor.
    cheers
    warrick
    Aug 2007
    you can disable the sensor with vcds
