Every time I've had a dealer service, the work to be done has been set out on a form that I've had to sign before work would commence. Can you remember if there was such a form, and if so, what was written on this form? It sounds like the 99k service was done a while ago, so you may not be able to remember.
Unless you have something in writing (like that statement of work form) from the service centre stating that the timing belt was to be changed, it will be your word against theirs.What do you guys think i should do or what would you do,
What I would do is essentially what you have done start by approaching/contacting the manager of the service centre with the facts:
- you were told at the 99k service that the timing belt would be changed, and that you were advised that the timing belt was bundled with the 'timing cover' part that was replaced (the name of the person who told you this might be handy)
- your logbook was stamped at the time of the 99k service and a note made that the timing belt was changed
- you are now being told that the belt is not part of the 'timing cover' replacement
- there was no mention of the timing belt as a separate part on invoice for the 99k service
- based on this new information, you are now concerned that the belt was not actually changed at the 99k service, despite your having requested and confirmed that it would be.
If you're not happy with the response from the service manager, go to the dealer principal.
