Results 1 to 5 of 5
Thread: Locked out of Passat B6
    Dec 2009
    Kew, VIC
    This appeared on the Rosstech (VagCom) list this morning — he's obviously not too bright or he'd have thought first, but it'd be good to help him out. If the Passat battery lives where it does on my Golf, getting to the terminals with the bonnet shut would be a work of art.
    "I locked the doors on a 2010 Passat B6 and removed the car battery for charging. Closed the hood after removing the battery.
    When I tried to open the door with the plastic key, the door handles would not release the door even though the plastic key turned.
    Now I am locked out with the fully charged battery outside.
    How do I get the doors to unlock if the plastic key would not work ?
    Help !"
    May 2010
    Melbourne, VIC
    Quote Originally Posted by Idle View Post
    Followed closely by an 'oh *****' moment, no doubt?
    This is the emergency key inside the 'cartridge', right?
    It could be that the lock mechanism is broken, or the key is the wrong one for the lock - most modern door lock mechanisms are designed to freewheel if the wrong key is used.
    Being a 2010, it'll still be under warranty, and if it's an Australian one, it should have VW Roadside Assist membership as well. I'd be ringing them for assistance.
    Oct 2006
    Have you tried through the boot? do the passat seats fold down actually?
    Dec 2008
    Sydney/Canberra
    Break the LHF window.
    They're only $90 or so.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2007
    ivanhoe vic
    Don't break the rear quarters on a wagon - expensive.
    B6 Passat Wagon No KESSY
