Can any one help me.
I want to put a mobile (blue tooth) phone cradle to the left of the steering wheel and run a power supply to the phone from under the dash. I don't want to visually see the power cables in the cigarette/power socket at the front as I want it to look neat. I have read how I can pull the dash apart and tap into the rear of the front cigarette lighter but is there anywhere else I can get positve and negative feeds to the phone from under the dash without extensive removal of the dash.
Tx
Craig
Ncle NSW
Candy White 07/10 R36 VW Wagon. sunroof, tint, RNS510.
You can tap into the fuse box which is to the right of the dash ( check the manual for location. use a spare fuse point (ie no fuse currently in the socket) which provides +12V (supply power is the top half of the fuse socket). to plug into the socket, you can use a 6.3mm Quick connect terminal. this is your +12v. **** make sure you fit a fuse shortly after the tQC connector near the socket.
for the ground you will need to drill into the metal work and use a metal thread.
once you have +12 and ground you can feed this through the dash to your desired location without too much trouble.
if you need more help i can do a photo,
the nice thing about this setup is you dont have to tap into any car wiring which is a worry.
I have used this concept to bypass the switched 12V to the rear +12V cig lighter on all the time to charge batteries.
had a passat tdi. now mb c class.
Cool. Thanks.
hi craig
attached is a pic of how i changed the rear 12v cig outlet to constant 12V power with the ignition off. if you want constant 12v you would plug into the top socket as i have ( just below the 5A fuse). the metal bracket below will give you a ground point.
Don't forget the fuse!. the supply point is probably off a 100A or similar fuse which if you blow that would likely take out a lot of the electrics
in my case the bottom socket is the fused outlet (bottom of the 2) to the rear 12v cigarette lighter.
hope this helps.
