VW have quoted me $280 for the parts and $300 labour (2 hours) as it requires the entire bumper to be removed.
Hi it looks like I have a leak in the wiper washer reservoir. It looks like a bit of a PITA to remove, inaccessible bolts etc has anyone done this if so is it less of a PITA than I think it is? Also is VW going to charge me an arm and a leg for a replacement? Its a 2009 Passat 3.2 awd. Ta
Thats about right...not that bad if you can take bumper off then you are in.....VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Are you sure its the bottle and not a split seal or hose?
They dont join with a o ring the are plastic welded together. It might be the pump. Pump o ring. Connector pipe or a rat bite....VDUB..
