Results 1 to 6 of 6
Thread: leak in wiper washer reservoir
    Aug 2012
    perth
    Hi it looks like I have a leak in the wiper washer reservoir. It looks like a bit of a PITA to remove, inaccessible bolts etc has anyone done this if so is it less of a PITA than I think it is? Also is VW going to charge me an arm and a leg for a replacement? Its a 2009 Passat 3.2 awd. Ta
    Aug 2012
    perth
    VW have quoted me $280 for the parts and $300 labour (2 hours) as it requires the entire bumper to be removed.
    Mar 2013
    Brisbane QLD
    Thats about right...not that bad if you can take bumper off then you are in.....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2013
    Brisbane QLD
    Are you sure its the bottle and not a split seal or hose?
    Aug 2012
    perth
    Quote Originally Posted by vdubmotorworx View Post
    Not 100% sure. But the reservoir doesn't drain completely. I can see it comes in 2 sections, water level gets to lower section and no longer leaks. I'm wondering if it could be the O ring that joins the 2 sections. Can't for the life of me find the leak.
    Mar 2013
    Brisbane QLD
    They dont join with a o ring the are plastic welded together. It might be the pump. Pump o ring. Connector pipe or a rat bite....VDUB..
