Results 1 to 8 of 8
Thread: keyless entry / push start button
    Mar 2009
    Hey all not sure if in right spot to post but if needs to be moved can someone do please. I have been searching youtube and came accross a passat cc with a push button start instead of using the key but also it have keyless entry so dont need to push the button on keys to get into car and slide key into hole to start has anyone done this to their cars? it looks aftermarket. cheers
    Pacific Paradise QLD
    [QUOTE=passat08;992136]Hey all not sure if in right spot to post but if needs to be moved can someone do please. I have been searching youtube and came accross a passat cc with a push button start instead of using the key but also it have keyless entry so dont need to push the button on keys to get into car and slide key into hole to start has anyone done this to their cars? it looks aftermarket. cheers[/QUOTE
    Comes in Passats I think from 2012 onward I wanted the wave your foot under rear bumper to open taildoor but it only comes in later models and was told its not a retrofit US models had it earlier
    Mar 2009
    I wander if can get aftermarket one
    Quote Originally Posted by passat08 View Post
    Probably have to change half the computer modules in the car to make it work.
    Dec 2012
    Sutherland Shire, Sydney
    I was in the USA a few months ago - one of the staff had a VW with no key hole in the door and a start button
    I was wondering what happens when your battery dies - how to open the door to get to the bonnet release
    (I'm sure VW will have thought of this)
    Quote Originally Posted by Martin View Post
    There is a cap in the end of the door handle that you can remove and use a key in it There was also an article on the GTI forum about how to fix that problem
    Apr 2010
    Might not be the exact same for you but you get the idea
    Aug 2007
    The system is called KESSY. Retrofit would be possible however require programming by dealer, especially immo modules etc.
    you need to put in all the harness to four doors, change door handles, add kessy computer etc etc. there was an entire loom and all modules on german ebay a little while ago abut I gave up, too much work.
