Page 4 of 17 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 162
Thread: Joining the queue of Passat owners with injector problems (TDI wagon carked it)
  1. #31
    Dec 2007
    ivanhoe vic
    used BP for a while as I got a 25% discount, since my discount stopped I have used Shell. Never used an independent. Depending on the state it all comes from one or two places. BP source from Mobil in Melbourne, Sydney is Shell.
    B6 Passat Wagon No KESSY
  2. #32
    Jun 2007
    sydney nsw
    Code
    What is the engine code that the injector electronics is most likely to fail??
    VW50.
  3. #33
    Feb 2008
    Outer East - Melbourne
    VW died too!
    not been on the forum in a while...
    a couple weeks back my Passat died at the lights. I thought it has stalled... thinks to my self "that's never happened before". I restart and I CHUG thru the lights only to stall again about 50m past the intersection.
    The "glow plug" dash light was flashing and the car would turn over but not start.
    Called road assist and car was towed to Berwin. They diagnose injector failure. As the car is in warranty they replaced all 4. It cost me a couple days car rental as they did not have a loaner available.
    Warranty up Feb 2011 and I have 63K on the clock so far.
    I'll be taking the extended warranty if I keep the car... thinking of getting an XC70.
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
  4. #34
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by vw50 View Post
    VW50.
    Usually on BMR 125kw TDI motors. Normally found in Passats and Golf V GTs.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  5. #35
    May 2007
    Quote Originally Posted by Umai Naa!! View Post
    Just had a look at my owners manual. Looks like the Engine Code is CBB.
    I this is not a troubled engine also...
  6. #36
    Dec 2008
    Sydney/Canberra
    The CBBB is related to the CBAB, which is known for intake flap and exhaust pressure sensor issues.
    Given that yours appears to be an MY10.5 build, I don't think you'll have any issues, as the parts used to rectify the problems I mentioned have been since revised.
    '01 Beetle 2.0
  7. #37
    May 2007
    Good to know, I only got the car 2mths ago...
    Will have to look into the intake flap / exhaust pressure sensor issues though!
  8. #38
    Feb 2009
    Hi
    Does anyone know if there is a difference between new(upgraded) injectors and wiring loom and old injectors/wiring? The reason I ask is my car {passat 125 tdi 2007 my2008}has done 113000 km and i bought it with 83000Km and i had a lot of problems with it but i have no idea what work was done for previous owner so it would be good if i can visually identify it .
    cheers
  9. #39
    Dec 2008
    Sydney/Canberra
    My advice would be to contact VW Customer Assist, and find out what warranty work has been done. The service book will tell you where it has been serviced, which, if you choose, you can contact, to see what else was done.
    As for injectors and the wiring harness that fires them, it's inside the cam cover out of sight. The injectors aren't an upgraded part, they're an exchange refurbished part through VW.
    '01 Beetle 2.0
  10. #40
    Jan 2008
    Sunshine Coast
    Mate what is the BMR? The GT TDI Golf has the BMN...???
    Perhaps that's the BMN with the Pasabalance shaft etc??
