Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 162
Thread: Joining the queue of Passat owners with injector problems (TDI wagon carked it)
  1. #21
    Feb 2008
    Perth WA
    Did you use a diesel fuel additive? I use Moreys Diesel Smoke Killer in our Golf and in T5 at every fill up, so far so good.
    No I havent. Does that product actually kill the smoke? The Passat tdi throws out a heap of smoke under heavy acceleration. I also have a Pug 308 touring that does the same thing...
    Mk 7.5 Golf R
  2. #22
    Dec 2007
    ivanhoe vic
    rang me today all good picking up in the morning not a bad turnaround time in the end.
    B6 Passat Wagon No KESSY
  3. #23
    May 2007
    Quote Originally Posted by OilBurna View Post
    Well done.
    Give a us a full report once picked up!
  4. #24
    Dec 2007
    ivanhoe vic
    Picked up this morning from Bayford vw at Epping they came and picked me up from epping station in a Tig.. Very impressive setup they have out there with the service area, free interent, games for the kids, good coffee machine, makes Essendon VW look pokey. Thank god for extended warranty final bill $3854!!! Only 2 were faulty and insurance only wanted to replace 2 but bayford pushed for all 4 to be replaced which was authorised including the wiring harness, apparently they have been redesigned so the fault will not occur. Car came back all sparkly clean as well including inside of my windscreen which had needed a good clean. Will be heading back there for my next service no question thanks to John for the great service.
  5. #25
    Jul 2005
    Newcastle, NSW
    These are good things, and great to hear!
  6. #26
    Dec 2007
    ivanhoe vic
    Thanks miki negative experience turned into a positive probably better it happened now and sorted rather than out of extended warranty either on the 3 years or 60,000km.
  7. #27
    May 2007
    I am really pleased that it has worked out for you.
    Drama...I know! However positive outcome.
  8. #28
    Adelaide hills, SA
    Quote Originally Posted by guthrie View Post
    Yes, it does. There is also Lucas fuel additive that maybe even better. The 300ml into tank of diesel and I don't see the smoke even on the first start up in the morning.
  9. #29
    Dec 2007
    ivanhoe vic
    Car seems to be running much smoother under acceleration also seems much less smoke as well?
  10. #30
    May 2007
    OilBurna, would I be out of line asking what type / brand of fuel you have used since owning the vehicle?
    I am wondering if some of the more "grocery" branded fuels / independents might be causing issues with our Diesels.
    I use the same bowser at the same BP Service Station for each and every fill (Diesel Ultimate).
