Well, after a lot of back and forth, I finally drove home my "new" MY10.5 R36 Wagon in Biscay Blue.
She has the RNS 510 SatNav, Sunroof, Adaptive Bi-Xenons and the original owner had aftermarket Bluetooth and Paddle shifters fitted (bigger than originals), but best of all adaptive chassis control!!!
As you do (when you work in IT), I upgraded the stereo and maps on the way home and started copying over music... well, easy stuff done.
For the slightly above average kms on the clock (just over 90k) and age it is in pretty good condition, with exception of the drivers seat which has the collapsing bolster and the adjustable lumbar and side bolsters aren't adjusting (no sound of motors or anything). I'm wide open to suggestion on how to fix or whether I should try VW for statutory warranty (fit for purpose, fit for use)... I could try and fix it myself if VW laughs at me... any one had this problem with the adjustable bolsters not adjusting? I also had the RACV comprehensive check done and for some reason they didn't pick this up in the report - might be an avenue to claim against them? might fall outside of the warranty terms, but worth a try?
Some others on here have done the Dynaudio speaker/amp upgrade.. something I'm considering doing, it doesn't look too hard, just fiddly. Anyone who has done it, is this worth doing? I do like good sound and love my music.
Any other suggestions for must do stuff? Retrofit power tailgate? Adaptive cruise? VCDS hacks or other cheaper stuff?
