Howdy Troops,
I've decided to post this little tidbit of information here
When I had my 2007 Jetta it had a cable coming out of the glove box that was supposed to work with any 'i'device (ipod / iphone etc etc.)
If you have a newer 'i' device and have connected it to the cable, you'll notice that it'll plug in and power up and you can hear music played through it, but it won't charge the 'i' device. This can get annoying as if like me, you use an ipod in the car and go on long trips, it'll run out of juice rather quickly, especially if you're playing back lossless music.
I came across a device that will charge your newer 'i' device via the inbuilt cable in the glovebox.
This is it dockStubz Charge Converter and 30-pin Pass-Through Adapter - Note the Charge Converter section - that's what made it work in my Jetta.
It's easy to use and works flawlessly. I've tried it on my iPad 2, iPhone 4 and Ipod Nano (4th gen) and they all charge while the cars ignition is on.
For $30 delivered, It's a bargain.
I now own a 2008 Passat and i've changed the stock head unit on it with a Pioneer Single DIN unit with a converter purchased from eBay.
Flawless bluetooth connectivity, dash menu system integration and steering-wheel controls. Highly reccommended if you're stuck with the old head unit (non Sat Nav).
If you're interested about the adapters and/or single DIN moulding I grabbed from eBay, shoot me a PM and i'll steer you in the right direction.
Peace,
Preest.
- You may not post replies
- You may not edit your posts
Forum Rules
