Results 1 to 8 of 8
Thread: intake manifold replaced
    Mar 2009
    Ok have a 08 passat tsi 2.0 just got the intake manifold replaced due to engine light coming on. So driving car home put foot down bit light flashes on then goes off he done a reading and there missfire now I checked ages ago on the plugs they are Platinum plugs could thst be the problem? They not that old. When the light does come in the car runs not good for bit basically if foot flat to floor runs bad but if slowly accelerate it is Ok. What could it be? Help anyone
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by passat08 View Post
    I had a 2.0 TSI with a small missfire under load, small enough for VAS to not detect it but I could feel it, ended up diagnosing it as two out of the four injectors, although you'll need a proper diagnosis mate.
    Mindarie, Perth (WA)
    Take it back to the repairer (dealer?)
    Mar 2009
    I want going to pay vw 900 dollars to do a 500 dollar job so had a mechanic do it that used to work there years ago.
    Erskineville, NSW
    Not sure what your point is. If he put it together wrong he should fix it. Even back-yarders give warranty unless they are total shonks.
    I used to warrant all my work when I was doing cashies.
    as I said...take it back to the repairer.
    Mar 2009
    How easy is it to check coil if faulty
    Sep 2005
    Maroubra Beach
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
