Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Installing & buying MDI and Bluetooth R36+ retailer in Sydney who makes wgn traymat
    Apr 2011
    Balgowlah Heights, NSW
    Thanks Lance B
    Just sent Marty a mail after I spoke to him after hours (he had his baby so felt bad...). Pm me re Stve's number and cost etc. Also let me know what you had installed in your R36 and any changes you are having done - as I'm embarking on this area I'd appreciate some commentary (and I know everyone's tasts / budget differs but we all want similar sound quality....).
    Thanks kleung
    I'm about to purchase the tray from the USA - and the stainless steel copy version I think too (it is US86 or thereabouts). Yours looks very similar to what I am looking to get. Why USA? 'Cos everywhere I went in Aussie (and NZ) just did not have what I wanted OR charged something a little more than I could swallow.
    Re dog - yes I'm not one to wish the worst and the standard barrier in the wagon would not stop her going through
    Feb 2008
    Sydney, Australia
    Quote Originally Posted by s12Raider View Post
    Thanks Lance B
    Thanks kleung
    I had a cage made from aluminium for our dalmatian. It just fits into the cargo area and has a hinged door that you access from the rear and is made from that aluminium that they use to make screen doors from, like a large diamond pattern each diamond may be 50mm(?). It is basically about a cube shape, but the rear part is slanted on an angle like the rear of the car. I am at work at the moment, so I can't measure the actual cage, but I did measure the area that it takes up when in the back and I am sure that these measurements would be reasonably accurate.
    The floor of the cage is 900mm from front to rear. This is made of a solid piece of auminium, probably 1.6-2mm thick with chequer plate.
    height about 720mm
    width is 900mm
    top of the cage is 650mm from front to rear.
    I hinged it at the top and have a couple of pins to secure it at the bottom.
    I'll try to take a pic if you like.
